Victorian Tiled Floor restoration at Buxton Outward Bound Centre
Derby University have a 58 acre outward bound centre in Buxton at the centre of the famous peak district. The manor which was previously a hotel is the hub of centre and caters for numerous outdoor pursuits including climbing, underground caving and canoeing; as you can imagine the floors in manor house get a fair amount of wear as students come and go in their boots and rucksacks. All this takes its toll and I was asked to restore a marvellous old Victorian tiled floor at the manor house.
Cleaning the Victorian Tiled Floor
The Victorian tiled floor was looking tired; any sealer that may have been applied previously had long since worn off. There were a few cracked and broken tiles which needed replacing and fortunately you can still source these tiles and so once this was done I set about cleaning the floor. To clean I used Tile Doctor Pro-Clean which is an alkaline product in conjunction with a buffing machine fitted with a black scrubbing pad; once the floor was clean I washed it down with clean water to remove any remaining chemical before sealing. I can recommend the use of a wet vacuum at this point as it makes the job of removing liquids from floors much faster.
Outward Bound Victorian Floor Before
Sealing the Victorian Tiled Floor
One the floor was dry I started the sealing process or applying five coats of Tile Doctor Seal and Go, this can take a while as it’s necessary to allow each coat to dry before applying the next. The sealer added a nice sheen to the floor and will provide protection to the Victorian tiles going forward; you can see the difference in the photographs.
Outward Bound Victorian Floor After
Source: Derby University Outward Bound Centre Victorian floor cleaning
