Tiled Floor Restoration at 13th Century Church
These beautiful Quarry tiled floors belong to a 13th century church in the heart of the old village of Frankton. I did some research on the internet and discovered that the church had gone through a major restoration in 1872 so it’s most probable the tiles date back to that time.
Victorian Floor Tile Cleaning Frankton Church
Cleaning Victorian Tiles
There were multiple quarry tiled floors that were all in need of a deep clean and seal; however there was concern that cleaning the tiles using conventional cleaning methods requiring a lot of water could result in damp permeating into the structure of the building and considering the age of the building may this could cause damage. With this in mind I ran some tests to work out an alternative and I worked out that the best alternative would be to use Acid Gel which would stay in place followed by a steam clean.
Victorian Floor Tiles Frankton Church Before Cleaning Victorian Floor Tiles Frankton Church Before Cleaning
There was quite a lot of floor to cover and I need to work in relatively small sections so it took two days to complete the cleaning. I used the method I worked out earlier applying Acid Gel, and then leaving it to dwell for ten minutes before working it in with a black scrubbing pad fitted to a buffing machine. The gel and resultant soil was then removed with a wet vacuum and then the section was steam cleaned to lift out any further dirt and neutralise the acid.
Victorian Floor Tiles Frankton Church During Cleaning
Sealing Victorian floor tiles
On the third day I returned to seal the floors; there are a number of sealers I could have used for this type of floor however with the building being as old as it was I wanted to ensure the tiles could breathe and any damp could rise up through the tiles. Additionally I wanted the sealer to bring out the best in the tiles so with these points in mind I sealed the floor using four coats of Tile Doctor Seal and Go extra which covers all these points and is the recommended sealer for Victorian and Quarry tiles.
Victorian Floor Tiles Frankton Church After Sealing Victorian Floor Tiles Frankton Church After Sealing
I think you will agree the floors now look fantastic and with the sealer to protect them they should stay this way for some time to come, although give the amount of traffic these floors receive I will be working out a maintenance plan for them.
Source: Church Floor Restoration Service in Warwickshire
One thought on “Tiled Floor Restoration at 13th Century Church
