Tile Doctor Acid Gel
Removing grout smears or efflorescence from tiled walls is a common problem and something we are often contacted about at Tile Doctor.  The solution is the use of an acid based product however liquids will run down walls and don’t hold in position long enough to dwell and get to work on the grout making the job more difficult.
Tile Doctor have now resolved this problem with the creation of a new pH1 blend of Phosphoric and Hydrochloric acids in a gel form and being a gel it is especially effective on vertical or sloped surface where where more dwell time is required.
Tile Doctor are the only company producing an Acid Gel for Tile and Stone, an innovation which has come about after listening to feedback from customers and the 50 Tile Doctors operating in the UK. This close working relationship allows Tile Doctor to respond quickly and to develop solutions to problems affecting the Tile and Stone industry.
Acid Gel is in stock and available in 1 and 5 litre bottles ready to order via the web site via the following link:  http://www.tiledoctor.co.uk/TD-Acid-Gel.asp
