Stone Floor cleaning at Car Dealership Office
These photographs are from the cleaning of a Travertine tiled floor installed in an old house in Dunmow that had been used as offices by employees of a Ford dealership. The house was empty when we started the cleaning process and you could see that the dirt had become ingrained into the tile and any sealer that had been present had now been worn away.
Travertine Tiles in Dunmow Office Before Cleaning
Cleaning Travertine Tile and Grout
We tackled the grouting first by applying Tile Doctor Pro-Clean (diluted 1 part cleaner to 3 parts water) which was left to dwell on the grout for about fifteen minutes before being scrubbed in using small stiff hand brushes. As you imagine this was time consuming but the grout came up really well so the end result was well worth the effort. The tiles were then cleaned using more Pro-Clean (diluted 1 part cleaner to 2 parts water) but this time we were able to use a scrubbing machine fitted with black pads. We scrubbed the tiles several times in order to bring them up to a good standard. The floor was also washed down at this point to remove the soiled cleaning solution, all liquids being removed using a wet vacuum.
Travertine Tiles in Dunmow Office During Cleaning
Burnishing Travertine Tile
The Pro-Clean worked well to clean the Travertine but if you want to restore the original appearance it needs to be burnished using a set of diamond encrusted burnishing pads. The pads come in a set and you start with the coarse pad and a little water and move on through to the very fine pads until the surface is pristine.
To protect the floor and bring up the appearance even further Tile Doctor Shine Powder was polished into the floor using a buffing pad, the powder add a deep finish to the appearance of the travertine and hardens on the surface to provide durable surface protection.
Travertine Tiles in Dunmow Office After Cleaning
I think you will agree we have managed quite a transformation; certainly the customer was very happy with the work.
Source: Commercial Floor Cleaning Service in South Essex
