Slippy Porcelain Tile Solutions
We were contacted by a builder who had recently laid Porcelain Tiles in an office reception in Wimbledon. Although he has laid this type of tile in various art galleries around London without problem, in this particular lobby which is situated next to a shopping centre the tiles were extremely slippery and the facilities manager wanted the tiles changed at the expense of the builder.
Antislip Application Porcelain Tile Wimbledon
Obviously this would have been an expensive option and so the builder contacted Tile Doctor for help. Initially he had considered having a member of his team apply the treatment however he realised that as a Tile Doctor applicator we had been trained to apply the treatment properly and this gave the facilities manager confidence it would have been applied to the correct standard so we were awarded the work and asked to carry it out on a Sunday when the building would be empty.
Applying the Anti-Slip Treatment
We arrived at the agreed time and were let in by the shopping centre security team. The area we were treating was around 25m2 so decided to work in 5m2 sections first cleaning the tile using the first stage Ant Slip product worked into the tile with a rotary floor machine fitted with a polypropylene brush head and then removing with a wet vacuum followed by rinsing with clean water.
We carried on with this process until the whole floor was done and let it dry before going onto the next stage to apply the Tile Doctor Anti slip (stage two) and leaving for between 3 to 5 minutes before applying the stage three which locks in the Anti Slip.
Antislip Porcelain Tile Wimbledon
The Anti Slip product is invisible to the eye however it’s very easy to test it’s been applied, all you need to do is wet the tile as the product only activates when it’s wet.
When we had finished the whole floor we then tested it again just to make sure that everything worked well we cleared away all the tools making sure we left the area tidy and safe and locked the building up.
The Job took us one night and the customer is now recommending us to all other sites that have had these tiles fitted.
Source: Porcelain Tile Cleaning Questions Answered
