Restoring Victorian Floor Tiles in a Surrey Cafe
At Tile Doctor, we don’t just offer our tile cleaning and sealing services to residential properties, such as flats and houses we also cover tile installations in commercial properties, such as hotels and restaurants as well as
In fact, commercial properties tend to experience much higher daily foot traffic than residential floors resulting in much more strain on the sealer. This of course wears down the sealer more quickly and once the sealer had worn away the tiles are vulnerable to dirt becoming ingrained which makes the floor difficult to clean.
This Cafe in Chertsey is very popular with staff from the nearby hospital, as well as residents in the local area. Naturally, the cafe gets very busy and the Victorian tiled floor had experienced heavy traffic and was marked by footprints from hundreds of hungry customers.
Cafe Floor Chertsey Before Cleaning
I was called in to help the cafe owner restore this original feature back to its best possible condition and then seal again to protect it.
Cleaning a Heavily Soiled Victorian Tiled Floor
Once the cafe staff had left for the evening, I moved the tables aside to avoid damaging them and laid down a strong dilution of Tile Doctor Pro Clean across the floor. This is our reliable alkaline cleaner which is designed to loosen the dirt on tiles and grout.
As the dirt was deeply ingrained in the stone, I scrubbed the floor using an abrasive 200 grit pad fitted to on rotary buffer. Within seconds the pad had worked its magic and I had a trail of filthy water to suck up using a wet vacuum machine.
Once the majority of the floor had been cleaned, I took to my knees to closely inspect the stone for dirt. Any particularly stubborn areas were tackled using a wire brush in combination with Tile Doctor Remove and Go, which is a heavy-duty cleaner/coatings remover which works well on removing any old sealers, paints and adhesives.
Sealing a Victorian Tiled Floor
Once the floor was clean, I washed and neutralised the surface with plain water. While I was packing up for the day I also installed my air-blower to aid the drying process overnight.
Two nights later I returned to the cafe to seal the tiles with Tile Doctor Colour Grow. Colour Grow is a colour enhancing sealer that impregnates into the pores of the tile to bring out the natural colours whilst adding a durable matte finish that acts as a barrier to dirt.
Cafe Floor Chertsey After Cleaning
As you can see from the photo above, the result was fantastic. In fact, the customer loved her newly restored floor so much that she even told me to help myself to any cake of choice, I do like a bonus!
Source: Victorian Tile and Grout Cleaning Service in Surrey
