Restoring Terrazzo Floor in a Surrey Church
Every so often I will get the chance to undertake tiled flooring restoration work in public buildings, and late last year I was asked to clean and seal a Terrazzo floor at a church in Redhill. The floor wasn’t in great condition; not only was it suffering from a significant amount of dirt due to a lack of proper maintenance, but it was also marked by several cracks. Overall, the appearance of the floor was very displeasing and the church was keen to have me in to complete some repairs, along with a deep clean and seal.
Terrazzo Flooring Redhill Church Before Restoration Terrazzo Flooring Redhill Church During Crack Repair
Cleaning and Burnishing a Terrazzo tiled floor
Upon initial inspection of the floor, I was unable to say for certain whether there was any old sealer remaining on the tiles so to ensure it was removed I began the cleaning process by applying a layer of Tile Doctor Remove & Go, which is a powerful cleaner/stripper designed to both break down old layers of sealant and lift out any ingrained dirt.
I then gave the floor a rinse with water to remove any excess cleaning product, before moving onto a different cleaning process, known as burnishing. Burnishing involves polishing the surface with to achieve an aesthetically pleasing sheen finish. The Tile Doctor burnishing system consists of four diamond encrusted burnishing pads with different levels of grit.
Terrazzo Flooring Redhill Church Part Cleaned Terrazzo Flooring Redhill Church Part Cleaned
I began by applying a Coarse burnishing pad, before working my way through the system with Medium, Fine and finally Very Fine pads to achieve a very refined, high quality polished finish, you need to use a little water to help lubricate the burnishing and you need to rinse the floor after each pad to remove the slurry.
Terrazzo Flooring Redhill Church Cleaning in Progress Terrazzo Flooring Redhill Church During Burnishing
Once the floor had been allowed to dry completely following both cleaning processes, I set about filling the cracks in the tiles with two part resin stone filler.
Terrazzo Flooring Redhill Church During Crack Repair Terrazzo Flooring Redhill Church Crack Filled
Then, once the filler had dried, I re-polished the floor using only the extra fine burnishing pad, focusing my attention along the crack lines. This really helped to reduce the evidence of cracks and left instead a smoothed surface.
Sealing a Terrazzo tiled floor
The final stage of the restoration involved sealing the Terrazzo tiles with Colour Grow, which is Tile Doctor’s colour intensifying sealer that impregnates the stone seeping into its pores to provide protecting the floor from within with a robust seal capable of withstanding the high amount of traffic experienced by church floors. The last step was to buff the entire area with a soft white buffing pad.
Terrazzo Flooring Redhill Church After Terrazzo Flooring Redhill Church After
The church was very pleased with the results, especially that they were able to show it off for last year’s Remembrance Sunday and left the following comment on the Tile Doctor feedback system:
“Many thanks for the work on our Terrazzo floors. It’s only when you see the before and after that you realise how grubby they had become. We have had loads of complimentary comments as to how good they look. Bill Bailey was a very personable and professional contractor who put himself out to work around our requirements and others working in the buildings at the same time. More than happy to recommend the company and Bill personally. Many thanks for a job well done.”
Terrazzo Flooring Redhill Church Before and After Restoration
Source: Cleaning and Maintaining Terrazzo Flooring in Surrey
One thought on “Restoring Terrazzo Floor in a Surrey Church
  1. Tile Doctor is the largest Tile and Stone cleaning network in the UK and have a number of services available including the provision of a regular maintenance service
