Restoring Office Quarry Tiles
A company based in the 17th century market town of Watlington were renovating their office space and decided to replace the carpet which had been glued to the floor below. Upon further inspection this turned out to be a Quarry Tiled Floor and they were keen to restore it and so we got the call.
Quarry Tiles Before Cleaning in Watlington
Restoring Quarry Tiles
I first covered the whole floor with Tile Doctor Remove and Go, leaving this to dwell for a while whilst I fitted a scrubbing pad to my rotary machine. Once the machine was ready the whole floor was scrubbed followed by a rinse with water; the resultant soil was then extracted from the floor using a wet vacuum. This process removed most of the glue so I repeated the process until satisfied all the glue had gone. Remove and Go lives up to its name and although normally used to remove sealers it will remove most other coatings as well. This process took up most of the day so after the final and thorough rinse I left the floor to dry aiming to come back the next day to seal it.
When I returned the next day the floor had white patches of effervescence on it where salts had been forced up through the tile as the water evaporated; this had to be dealt with before the tiles could be sealed so I spent the second day scrubbing the entire floor with Grout Clean Up to remove it, after finishing the floor was given another thorough rinse to remove any product from the floor and used the wet vacuum again to get it as dry as possible.
Sealing a Quarry Tiled floor
I returned the third day to a nice dry and most importantly clean floor. To seal Quarry tiles I usually go for Tile Doctor Seal and Go as it’s water based (so no smell) and it adds a nice shine to the floor; however in this case being an office environment with a lot of heavy traffic I decided to go with Tile Doctor Colour Grow which is an impregnating sealer that soaks into the pores of the tile and is likely to be more durable, it also enhances the natural colours in the tile leading to a very nice finish.
Quarry Tiles After Cleaning in Watlington
I think you will agree the final result was a remarkable transformation
Source: Office Tiled Floor Restoration in Oxfordshire
One thought on “Restoring Office Quarry Tiles
