Removing Stubborn Chlorine from Leisure Centre pool tiles
Not sure if these pictures do the job justice but we had a tough job on our hands cleaning the anti-slip ceramic tiles around this swimming pool at a leisure centre near Kendal in Cumbria. Including the changing rooms the area measured approximately 1110m2 and fortunately most of the tiles were just in need of a good scrub and clean but there were also some areas where there was a build-up of hardened chlorine around the drains and dips in the floor allowing it to settle and calcify on the tile.
Hardened Chlorine Around Spa Area Hardened Chlorine Around Changing Area
To clean the tile we used Tile Doctor Pro-clean which is a heavy duty cleaning product specifically designed for tile cleaning. The area was large but fortunately only about 10m2 needed to be cleaned by hand for the rest we were able to use a rotary machine fitted with and a Black Buffing pad; lots of rinsing was required and we used a wet vacuum to remove the water as naturally it was important not to let any chemical contaminate the pool.
Swimming Pool Tile Cleaning in Action
For the difficult areas that had to be done by hand we used a Fein Multimaster which is a versatile electric tool that has a special attachment that allowed us to remove the Chlorine build-up
Spa Area After Cleaning
The area took two of us four days to complete and the client was pleased with the different we made and left the following feedback on our website.
They arrived on the day they said and they finished on the day they said and we were well satisfied with both their work and professionalism and would have no hesitation in recommending them to future clients
Source: Swimming Pool Tile Cleaning in Cumbria
