Regular Maintenance of Restaurant Tiles
I was asked by my local Indian restaurant in South Croydon if I could improve the look of their marble tiles in the reception area of the restaurant. They had been laid several years ago and now the sealer was failing and dirt was becoming ingrained in the tile and especially the grout which had gone dark.
Marble Tiles Indian Restaurant South Croydon Before Marble Tiles Indian Restaurant South Croydon Before
Marble Tile and Grout Cleaning
To get the grout clean and remove the surface dirt we started with the application of a coarse grade diamond encrusted burnishing pad, the pad is used in conjunction with a little water which helps lubricate the process and it effectively cuts back the layer of grime from the surface. Rotary pads do struggle to reach into the grout lines so a medium dilution of Tile Doctor Pro-Clean which is a heavy duty tile and grout cleaner that’s safe to use on natural stone and grout was also scrubbed into the grout by hand using a stiff brush.
Marble Tiles Indian Restaurant South Croydon During Cleaning Marble Tiles Indian Restaurant South Croydon During Cleaning
The floor was then rinsed to remove the now dirty water and cleaning solution and we moved on to polishing the floor using a medium grade, fine and then super fine pads to build the surface shine backup. The floor was rinsed with water in-between each pad and then dried out as thoroughly as possible using large air movers.
Sealing Marble Floor Tiles
Normally I would have finished off with the application of Tile Doctor Shine Powder to give it a mirror like finish but the owner was happy with the way it looked and so once the floor had dried we moved onto sealing it with two coats of Tile Doctor Colour Grow which is an impregnating sealer that works from the inside by occupying the pores within the stone, it also enhance the colours within natural stone.
Marble Tiles Indian Restaurant South Croydon After Cleaning Marble Tiles Indian Restaurant South Croydon After Cleaning
The owner was over the moon with the results and has now engaged us to maintain the floor on a regular basis.
Marble Tiles Indian Restaurant South Croydon Before and After Marble Tiles Indian Restaurant South Croydon Before and After
Source: Tile, Stone and Grout Maintenance services in East-Surrey
One thought on “Regular Maintenance of Restaurant Tiles
