Quarry Tile Floor Restoration at a School in Leatherhead
This Quarry Tile floor was found under carpeting at a school in Leatherhead, Surrey during a refurbishment; you can see from the photograph what a terrible state it was in however the school was keen to keep the tiles and we were brought in to restore them.
Leatherhead Quarry Tiles before restoration
Cleaning Quarry Tiles
There was a lot of dirt on the tiles so a strong solution of Tile Doctor Pro-Clean was applied to the floor and left to soak in for around 20 minutes; Pro-Clean is a multipurpose alkaline cleaning product designed specifically for cleaning tile and stone. The floor was then scrubbed using a rotary machine fitted with a black scrubbing pad and then thoroughly rinsed with water which was removed using a wet vacuum. Once the Quarry tiles were dry it was possible to spot the areas in need of further attention and these were scrubbed by hand together with more Pro-Clean.
Once happy with the floor it was left to dry off overnight and we came back the next day to seal it with six coats of Tile Doctor Seal and Go which will provide future surface stain protection and also leaves a nice deep low sheen. The builders working on the refurbishment couldn’t believe the finish, I must admit looking at the photographs it was quite a transformation.
Leatherhead Quarry Tiles after restoration
Source: Leatherhead School Quarry Tiles Restored
