Night Cleaning Ceramic Supermarket Tiles
Photographs below from a Mini-Market in Lewes where high foot traffic was taking its toll on the Ceramic tiled floor which was now is need a dramatic deep clean.
Before Cleaning Dirty Ceramic Tiles in Lewes Mini Market
Shop Floor Cleaning
As the shop is open from 6am-11pm I had to work through the night. I started by applying a medium dilution of Tile Doctor Pro-Clean to shift the muck, this was left to soak in for a while before being scrubbed into the floor using a buffing machine fitted with a scrubbing pad and stiff brush along the grout lines. The floor was then rinsed with warm water which was then extracted using a wet vacuum. I had to repeat the process in stubborn areas but as you can see from the pictures the result was incredible, just look at the pictures!
Ceramic tiles are glazed so do not need sealing and as there is no sealer the floor can now be maintain using a regular floor cleaning product. Hopefully they can keep on top of the cleaning however it is a busy floor with hundreds of people walking on it every day so if they do struggle we are always happy to do a regular maintenance clean for them.
After Cleaning Dirty Ceramic Tiles in Lewes Mini Market
Source: Professional Tile, Stone and Grout cleaning service in East Sussex
