New Build Travertine Clean for Construction Company
Details below of a newly laid Travertine Honed & Filled floor in Aylesbury that needed stripping and re-sealing. The work was done at the request of a building company who had just completed a pair of semi-detached houses laid with Travertine tiles on the ground floor. Unfortunately the tiling contractor had failed to clean the tile surface properly before sealing and had trapped particles of dust and debris into the sealer, as a result the whole floor was as rough as sandpaper and needed to be stripped and re-sealed prior to their clients moving in the following week.
Travertine Floor Aylesbury Before
Cleaning Travertine Tile
To remove the existing sealer and to polish the stone we used the Tile Doctor diamond burnishing system. This involves burnishing the floor with diamond encrusted pads fitted to a heavy rotary machine, the system consists of a set of four seventeen inch coloured pads and you work your way through the pads from red (sealer removal) through to green (final polishing). This work returned the stone to its original condition ready for sealing.
Travertine Floor Aylesbury After
Sealing Travertine Tile
We sealed the floor with three coats of Tile Doctor Colour Grow which provides excellent stain protection whilst enhancing the natural colours in the stone. The building company was pleased that we had managed to resolve the problem before the owners moved in as it had avoided an embarrassing situation for them. Interestingly we have since completed three other jobs with this same type of problem.
Source: New Build Travertine Tile Cleaning in Buckinghamshire
