Marble Floor Polishing in Belgravia
We were asked to polish this marble floor in Eaton Square which is in Belgravia one of the most historic residential parts of London, a short distance from Buckingham Palace and Knightsbridge.
Cleaning a Marble Tiled Floor
There were a lot of scratches in the Marble floor and it was also looking dull, so we set about first by giving it a good clean using Tile Doctor Pro-Clean which is an strong alkaline product designed for use on stone floors. It’s important to clean the floor before polishing to ensure there’s no dirt or grit on the floor which might get ground into the floor during polishing making the problem worse.
Marble Floor Polishing in Belgravia Marble Floor Polishing in Belgravia
Polishing Marble Tiles
Once the floor was clean we started the polishing process with a Red Burnishing pad fitted to a rotary machine, the pads are diamond encrusted and can remove deep scratches. We went over the floor carefully covering every tile four times and then followed up with the white, yellow and then green polishing pads, each one polishes the floor to a higher degree. The next step was to apply Tile Doctor Shine crystallising powder with a little water polished in with our polishing machine fitted with a natural fibre pad; this step gives the floor a tough durable finish. The floor was then thoroughly rinsed to remove any residues left on the floor all before giving it a final re-polish to bring out a deep high shine.
Source: Marble tiled floor cleaned and polished in London
