Holiday Home Floor Cleaning
This Limestone tiled floor was installed in a holiday rental cottage in Chipping Norton which had a regular change of occupants and was in need of a deep clean and polish. To deep clean stone floors such as Limestone, Marble and Travertine the floor needs to be burnished with diamond encrusted pads.
Limestone Floor Chipping Norton Before
Cleaning Limestone Floor Tiles
The floor was given a quick wash with Tile Doctor Neutral Cleaner in order to remove any surface grit and then cleaned using a set of Burnishing pads fitted to a rotary machine. The burnishing pads come in four different types and you work your way through them starting off with a course stripper pad with a little just water and then carry on with the white pad and then the yellow pad until the floor is thoroughly cleaned and any previous sealer removed. Next step was to use Tile Doctor Pro-Clean along the grout lines with a stiff brush to get the grout cleaner. To bring up the polish on the Limestone tiles I used a polishing pad which is the last in the set of the four burnishing pads. The floor was still wet at this stage so an air dryer machine was used to speed up the drying process.
Sealing Limestone Floor Tiles
Once the floor was dry we set about sealing it using two coats of Tile Doctor Colour Grow which is a colour enhancing sealer designed to provide maximum stain protection on natural stone floors whilst bringing out the deep colour in the stone. The last step was to buff the floor to a nice shine with a rotary machine fitted with a white pad.
Limestone Floor Chipping Norton After
Source: Limestone holiday cottage floor maintenance in Cambridgeshire
