Factory Floor Cleaning
We recently carried out a clean for a printing company in the London Borough of Croydon, who had removed some machinery and had found that the exposed floor had large amounts of latex glue left on the floor. In fact the floor was in such a bad state due to the amount of dirt, oil and glue no one could determine what type of floor we were dealing with.
My first task was to scrub the dirt away using a strong dilution of Tile Doctor Pro-Clean followed by a good rinse, Pro-Clean is a strong alkaline cleaner so it’s safe to use on all sorts of floors and won’t eat into the surface like an acidic cleaners. Once the dirt was removed we discovered the floor was in fact resin based.
Latex Glue Removal
The next thing to do was remove the glue for the floor which was really hard to do due to the thick build-up. We first started with steamers to heat the glue and then used large floor scrapers to lift as much as we could, finally we soaked the area with Tile Doctor Remove and Go and left the solution to Dwell for an hour after which we were able to scrape the remaining glue off.
Last but not least we gave the floor one more scrub with a weak dilution of Pro-Clean and a final rinse.
Source: Removing Glue and Cleaning a Factory Floor in Croydon
