End of Tenancy Bathroom Tile Refresh
This bath with shower over was located at a rental property in the town of Chessington that had been recently vacated by students. I was called in by the landlord who was looking to re-rent the property. The request was to tidy up the ceramic tiles in the shower and bath area and to make it look decent again for the next batch of soap-dodgers. We often get asked to do end of tenancy tile cleans and have seen a lot worse than this one so I was confident it could be made to look like new again.
Dirty Ceramic Bath Tiles in Chessington before cleaning
The main problem was the grout had become darkened and stained from dirt and the dyes in soaps etc., the mastic sealant between the tile and the bath also needed replacing.
Cleaning Ceramic Tiled Shower Cubicle
To get the tile and grout clean I sprayed on Tile Doctor Oxy-Gel which works better than liquid products as being gel based it sticks to the wall tile and grout and really gets to work breaking down the dirt. I left this for a few minutes before scrubbing it in and then rinsing it off with water.
Whist this was drying I started to strip out the old mastic seal and tidied up the mess that had fallen into the bathtub using a vacuum.
Grout Colouring Shower Wall Tiles
With the tiles now clean and fresh grout dried the next step was to apply a White Grout Colourant to ensure all the grout had a consistent appearance. Although time consuming the grout colourant is easily applied with a small brush and then you wipe off any excess that gets onto the tile before it dries.
I left the grout colourant to dry for 30 minutes before applying another coat and once this had dried I set about adding a new mastic seal between the wall tile and bath. I always use a high quality silicone sealant for this; I never use cheap sealant as they soon discolour and can shrink resulting in water ingress problems.
Dirty Ceramic Bath Tiles in Chessington after cleaning
It takes a little time but the bathroom now looks much fresher and ready for the next tenants.
Source: Ceramic Tile and Grout Cleaning Service in West Surrey
