Coffee Shop Floor Cleaning Contract
The Ceramic tiles with dark grout were installed in a Bedford Coffee Shop where we have a regular contract to deep clean the tile and grout, whilst we appreciate the regular work you do have to work out of hours to minimise impact to trade. It’s worth noting that many commercial tiling installations do avoid white grout as it can get dirty quite quickly and will be difficult to clean if badly stained, not that that’s a problem for Tile Doctor as we have a solution for most problems.
Cleaning Ceramic Floor Tiles
This was a general maintenance clean so a dilution of Tile Doctor Pro-Clean was applied to the floor and left to soak in for 20 minutes or so before giving the floor a thorough clean using a Rotovac machine which applies and removes water at high pressure to remove the dirt and rinse the floor. Once this was done we took the opportunity to apply more Pro-Clean to the grout and hand scrubbed along the grout lines using a stiff brush to ensure the black grout was clean.
Ceramic Tiles Bedford Coffee Shop Before and after
Ceramic tiles don’t normally need a sealer so once all the tile and grout was clean and was dry we were done.
Source: Ceramic Coffee Shop Floor Tiles Cleaned in Bedford
