Cleaning Travertine tiles at a University
This rather dirty Travertine tiled floor is located in the reception area of the hotel and conference centre of the Cranfield University, apparently the tiles had been laid ten years prior and had not been properly cleaned and resealed since.
Cleaning Tumbled Travertine Tiles
Before starting we covered all the area around the floor with masking tape and plastic sheeting to protect it from any splashing which can happen when you’re using high speed floor machines.
The tiles were in need of a good deep clean so a strong dilution of Tile Doctor Pro-Clean was applied to the floor and left to soak into the tile for twenty minutes before being scrubbed in with a using a rotary machine fitted with a scrubbing pad. The soiled solution was rinsed off using clean water and extracted using a wet vacuum repeating the process until you could see the improvement in the floor. A stiff hand brush was also used along the grout lines with more Pro-Clean to get them clean.
Travertine Tiles Before Cleaning at Cranfield University Travertine Tiles After Cleaning at Cranfield University
Burnishing Travertine Tiles
To restore the shine back to the travertine we used a set of diamond encrusted burnishing pads starting with a coarse pad and a little water fitted to a heavy rotary machine, the coarse pad strips off any remaining dirt and seal from the floor, the resulting slurry was then removed using a wet vacuum.
Once finished with the course pad we moved on to the medium and fine pads again with a little water until the floor was polished. The final “Very Fine” pad brings up the polish on the floor and buffs it to a nice shine.
Sealing Travertine Tiles
Last step was to seal the tiles which would prevent any dirt getting trapped in the pores making it easy to clean and ensuring it keeps it appearance for longer. For this we used two coats of Tile Doctor Colour Grow which as well as sealing the tiles works to bring out the natural colours in the stone.
The customer was very happy with the results and commented that they thought the transformation was amazing.
Source: Commercial Travertine Tile Cleaning in Bedfordshire
One thought on “Cleaning Travertine tiles at a University
