Cleaning Quarry Tiles in a Commercial Kitchen
This job was to strip and re-seal these Quarry tiles installed in a commercial kitchen which was undergoing refurbishment at a canteen in Rushden, Northamptonshire. The tile finish had dulled and there was a lot of staining to the grout.
Quarry Tiles in Rushden before cleaning
As there was little in the way of kitchen units to protect I go straight down to stripping down the floor using a strong dilution of Tile Doctor Pro-Clean which is a multi-purpose cleaner/stripper that’s safe to use on stone, tile and grout. The solution was applied with a mop and left it to dwell on the floor for twenty minutes in order to give it chance to soak into the tile surface and get to work on the existing sealer and dirt. It was then worked into the floor using a rotary machine fitted with a black scrubbing pad and stiff hand brushes were used along the grout lines to get the grout clean. The resulting soiled solution was picked up with a wet and dry vacuum and the floor was then rinsed with clean water to neutralise the tile and stubborn areas re-treated. Once I was happy the floor was given a final rinse and then left to dry overnight ready for sealing the next day.
After checking the tiles had dried I proceeded to seal the floor using four coats of Tile Doctor Seal and Go which will protect the floor from staining going forward and also adds a nice shine to the tile.
Quarry Tiles in Rushden After cleaning
Source: Quarry Tile floor cleaning services in Northamptonshire
