Cleaning Etched Anti Slip Tiles
You may recall a Limestone job I did recently at a Manchester country club in Hale. This Anti-Slip porcelain floor was installed at the same location in the passageway on route to the toilets and in the toilets themselves. Slips and falls can be a huge problem for buildings with public areas and so tiles which have been etched to make a normally smooth surface rough make perfect sense, the downside of course is that those rough surfaces trap dirt and are difficult to clean. Tile Doctor have a chemical Anti-Slip alternative that only activates when the tile get wet that doesn’t require the tile to be etched but it does need to re-applied every few years.
Anti Slip Tiled Hallway Before Cleaning Anti Slip Tiled Hallway Before Cleaning
Cleaning Anti Slip Floor Tiles
The floor tiled need a deep clean to bring out the ingrained dirt so we applied a strong solution of Tile Doctor Pro-Clean using two parts water to one part Pro-Clean and left it to soak into the tile for twenty minutes. The solution was then scrubbed into the tile using a rotary machine fitted with a black scrubbing pad. You could see the dirt coming out the pores of the tile and the resultant soiled solution was removed using a wet vacuum before washing the tiles down with clean water.
Anti Slip Tiled Hallway After Cleaning Anti Slip Tiled Hallway After Cleaning
Including the ladies, gents and hallway there was a lot of floor area to cover and some of the stubborn areas had to be re-treated so it was a long job but I think you will agree the floor now looks great.
Source: Commercial Tile Cleaning Problems solved in Manchester
