Cleaning and Sealing 120m2 of Slate Tiles at an Enterprise Centre
These photographs are taken at an Enterprise Centre in Millom where local business are encouraged to network and they also offer various training courses, all of which results in a large amount of people coming and going across the 120m2 of rough black Slate which covers the communal areas. Interestingly enough this is not the first time we have cleaned and sealed this floor with the last visit being five years ago. Five years of wear and tear had taken its toll on the tiles though and the black Slate was looking tired but not horrendous given its location so I think it’s fair to say the sealer had performed well over the Intermitting period.
Rough Black Slate Millom Before Cleaning
Cleaning Rough Black Slate
As I mentioned before the area in total was about 120m2 which is a large area so we operated in sections working around the public and ensuring the correct signage was displayed were relevant.
To clean the Slate tile and grout and remove the remaining sealer the floor a good deep clean using a dilution of Tile Doctor Remove and Go leaving it to soak in for fifteen minutes before working it in with a black scrubbing pad fitted to a rotary buffing machine. This process was followed by rinsing and cleaning with fresh water, stubborn areas were retreated and the water was removed using a wet vacuum to the get the floor as dry as possible.
Sealing Rough Black Slate
Once the section of floor was clean we left it to dry and moved onto cleaning the next section coming back later to seal it which we did with two coats of Tile Doctor Colour Grow which is an impregnating sealer that occupies the pores preventing contaminates from becoming ingrained. Colour Grow is also a colour enhancing sealer that brings out the deep colour in the slate.
Rough Black Slate Millom After Cleaning
The customer knew about using the right cleaning solution for regular cleaning however as it had been five years since our last visit we thought it best to remind them and recommend the use of Tile Doctor Neutral Cleaner which will not reduce the life of the sealer like an acidic cleaning product would.
Source: Commercial Tile and Stone Cleaning and Sealing in Lancashire
