Cleaning a Vinyl floor at a Coventry church
The great thing about being in the floor cleaning business is that the equipment we use are very flexible and allow the cleaning of many surfaces from Tile, Stone, Grout and Carpet through to in this case a Vinyl floor at Church in Wyken.
Vinyl floor in Wyken before cleaning Vinyl floor in Wyken before cleaning
Cleaning Vinyl Flooring
You can see from the photograph that although the floor was in good physical condition it was dirty and in need of a really deep clean. To do this the floor was mechanically scrubbed using a rotary machine fitted with a scrubbing pad and a solution of Tile Doctor Pro-Clean which is a very flexible heavy duty cleaning product primarily designed for Tile, Stone and Grout but equally effective on Vinyl floors as well. The soiled cleaning solution was then washed away with water which was removed using a wet vacuum and left to dry.
Vinyl floor in Wyken during cleaning Vinyl floor in Wyken during cleaning
Sealing Vinyl
Once the floor was dry three coats of Tile Doctor Seal and Go were applied to the surface which restored the shine finish. You have to wait for a coat to dry before applying the next so this process can take a while to complete.
Vinyl floor in Wyken after cleaning Vinyl floor in Wyken after cleaning
Source: Commerical and Residential Vinyl floor cleaning services in Coventry
One thought on “Cleaning a Vinyl floor at a Coventry church
