Cleaning a Manchester Country Club Stone Floor
This beautiful Limestone tiled floor was installed at a busy country club in Hale, Manchester around eighteen months prior and had seen significant foot traffic with around 500 people traversing it daily. The floor was taking a significant amount of punishment and although regularly cleaned the dirt had started to become ingrained into the stone and the maintenance team were struggling to keep it looking good, I also suspect that the cleaning product used on the floor may have accelerated the degradation of the sealer leading to the premature ingress of dirt.
Cleaning Limestone Floor Tiles
The floor was given a quick wash with Tile Doctor Neutral Cleaner in order to remove any surface grit and then cleaned using a set of Burnishing pads fitted to a rotary machine. The burnishing pads come in four different types and you work your way through them starting off with a course stripper pad with a little just water and then carry on with the white pad and then the yellow pad until the floor is thoroughly cleaned and any previous sealer removed. Next step was to use Tile Doctor Pro-Clean along the grout lines with a stiff brush to get the grout clean as well. To bring up the polish on the Limestone tiles I used a green polishing pad which is the last in the set of the four burnishing pads.
Sealing Limestone Floor Tiles
Once the floor was dry we set about sealing it using two coats of Tile Doctor Colour Grow which is a colour enhancing sealer designed to provide maximum stain protection on natural stone floors whilst bringing out the deep colour in the stone. The last step was to buff the floor to a nice shine with a rotary machine fitted with a white pad.
The Limestone floor is now backed to its best and I took the time to explain the need to use a neutral cleaning product such as Tile Doctor Neutral Cleaner on the stone in future.
Source: Limestone Floor Cleaned, Polished and Sealed at a Hale Country Club
