Applying Anti-Slip to a Golf Course Changing Rooms
I recently paid a visit to a Golf Club in Derbyshire to assist local Tile Doctor Steve Carpenter with the application of Anti-Slip treatment to the 6inch porcelain tiles in the men’s changing rooms. This is the advantage of being a member of a large network, if a fellow member needs assistance on a time consuming job they can just ask for assistance. In this case the floor was only around 12m2 but the Golf Club were hosting a Tournament later that afternoon and needed the work completing before 1pm.
Anti-Slip Preparation Derbyshire Golf Course
Cleaning Porcelain Tiles ready for Anti-Slip treatment
For best results the Anti-Slip treatment requires a clean surface so the first job was to give the tiles a thorough wash using Tile Doctor Pro-Clean worked into the floor with a rotary machine fitted with a scrubbing pad. The resultant dirty cleaning solution was then removed using a wet vacuum and the floor rinsed with clean water.
Applying Anti-Slip treatment to Porcelain tiles
The next step was to apply the Priming and Locking solution to the tile surface diluted one part solution to four parts water and this was left to dry. Once dry we applied the Anti-Slip treatment ensuring the tile was kept wet for up to 20 minutes in the process. The last step in the treatment was to re-apply the diluted Priming and Locking solution before the floor fully dried, it’s this last step that activates the treatment and locks it in place. There’s no need to wait for the floor to dry at this point it can be used immediately after the last step has been applied.
Anti-Slip Treatment Derbyshire Golf Course
To test the floor I invited the manager to try the floor dry and wet so he could experience the improvement in surface friction on a wet surface for himself. The treatment worked well and the manager was impressed, not only that we managed to complete the job with 45 minutes to spare.
For after care we recommend the floor should be cleaned daily by damp mopping with our Neutral Tile Cleaner, diluted at 35ml per 5-Litres of water periodically scrubbing the floor with a deck brush.
Source: Residential and Commercial Tile, Stone and Grout Cleaning in Lancashire
One thought on “Applying Anti-Slip to a Golf Course Changing Rooms
